JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
aabshire
Dec 23, 2017Apprentice
Well less than 1 hour with firmware R7000-V1.0.9.20_1.2.28 and down from 28 devices attached to 15. Turned off 5 ghz and guest again to see if that stabilizes it like the prior release(s)
- Stooby2Dec 23, 2017Tutor
aabshire wrote:Well less than 1 hour with firmware R7000-V1.0.9.20_1.2.28 and down from 28 devices attached to 15. Turned off 5 ghz and guest again to see if that stabilizes it like the prior release(s)
Same here - Nest stopped communicating as did my network wifi printer. Switched off 5ghz and rebooted and everything is back again. So V1.0.9.20 isn't the solution.
- HWAMDec 23, 2017ApprenticePlease tell me if you still are able to ping the devices. Do they still reply on a ping? In my case I always get a reply. No communication possible but I still reply on a ping.
- aabshireDec 23, 2017Apprentice
It had it occur again after I had turned of the 5ghz radio, noticed I have the SSID broadcast still checked for 5 ghz & guest. Turned that off and so far so good. Strange
Had the "No Internet" pop up on my laptop and my android loss connection. @ around 16:46 or so. Checked the log and found this: (looks like DHCP refresh).
[DHCP IP: (192.168.0.107)] to MAC address 88:DE:A9:10:A2:BD, Saturday, Dec 23,2017 16:48:05
[DHCP IP: (192.168.0.109)] to MAC address 08:05:81:3C:C6:A5, Saturday, Dec 23,2017 16:48:04
[DHCP IP: (192.168.0.152)] to MAC address 48:D6:D5:F3:90:02, Saturday, Dec 23,2017 16:48:00
[DHCP IP: (192.168.0.105)] to MAC address 10:F1:F2:81:FF:A6, Saturday, Dec 23,2017 16:47:59
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [159.127.42.140], Saturday, Dec 23,2017 16:46:06
[DoS attack: ACK Scan] attack packets in last 20 sec from ip [159.127.42.140], Saturday, Dec 23,2017 16:45:58
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [205.180.87.140], Saturday, Dec 23,2017 16:45:46
[DoS attack: ACK Scan] attack packets in last 20 sec from ip [205.180.87.140], Saturday, Dec 23,2017 16:45:37
