JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Stooby2
Dec 23, 2017Tutor
aabshire wrote:Well less than 1 hour with firmware R7000-V1.0.9.20_1.2.28 and down from 28 devices attached to 15. Turned off 5 ghz and guest again to see if that stabilizes it like the prior release(s)
Same here - Nest stopped communicating as did my network wifi printer. Switched off 5ghz and rebooted and everything is back again. So V1.0.9.20 isn't the solution.
HWAM
Dec 23, 2017Apprentice
Please tell me if you still are able to ping the devices. Do they still reply on a ping? In my case I always get a reply. No communication possible but I still reply on a ping.
