JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Jan1959
Dec 23, 2017Aspirant
Same problem with my router.
Do not understand why Netgear is not capable of getting the 2.4 bandwidth working. Should be top priority.
HWAM
Dec 23, 2017Apprentice
Please tell me if you still are able to ping the devices. Do they still reply on a ping? In my case I always get a reply. No communication possible but the devices still reply on a ping. Please test while you have the problem. Try to ping a 2.4GHz device from a wired device.
