JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AtoZ
Dec 23, 2017Apprentice
Do we know for a fact that advanced tomato fixes all the problems and gives us back the speed that's expected? I don't know the answer to this and I am very new to advanced tomato. Thanks in advance for your response.
brdoddsjr
Has the hot fix worked for anyone? I see 1 post it did not help.
