JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
aq123
Dec 23, 2017Initiate
Just purchased and installed my R7000 and my wifi speed is also horrible. My normal max is around 60mbps, but now I am getting in 10-15 when on 2.4ghz . I am 10 feet away from the router. I can connect my phone (my only AC device) using 5 and get around 50mbps, but when I connect to my old Linksys Router I get 61mbps on both 2.4 and 5ghz. Something is definitely not right.
QOS is off, Smart Control is off. devices are on different SSID (but same thing happens when they are on the same SSID)
What would cause this?
FW: 1.0.9.18_1.2.27
