JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Davide66IT
Dec 24, 2017Initiate
After installing the firmware 1.0.9.18, I found that one device- Samsung Galaxy A3 was no more connected to internet.
It was connected to the internal LAN - respended properly to ping - but di dnot navigate.
Any troubleshooting action on the phone did not fix the problem.
Reverting to previous firmware 1.0.9.12 fixed the problem - without any other change - and the device could again navigate properly
