JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
aabshire
Dec 24, 2017Apprentice
I started noticing that my phone was not accessing the internet even though it showed connected to wifi. I login into the router and see that my connected devices go from 30 to 12-15 and once I refesh the view it is back to the 30 connected and when I look at the log I seem to be seeing a lot more DHCP renewals than before.
