JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
aabshire
Dec 24, 2017Apprentice
I started noticing that my phone was not accessing the internet even though it showed connected to wifi. I login into the router and see that my connected devices go from 30 to 12-15 and once I refesh the view it is back to the 30 connected and when I look at the log I seem to be seeing a lot more DHCP renewals than before.
- TimepilotDec 24, 2017Guide
Ok - turned off guest networks (2.4G and 5G) - been totally stable for 36 hrs now- so fingers crossed and certainly a lot better than previously
Still have all 2.4 and 5G devices connected whereas that hasn't been the case for several weeks
- AaronB483Dec 24, 2017Aspirant
I have been struggling with this issue. Just to add another detail, Printing: I thought at first that I can no long print to my wifi printer(Canon) and my Brother laser attacted to the router. Nothing happen for 10 minutes but Finally both took off and printed. I have gone back to an older firmware and no chance. I am hoping that what one person in this discussion said they hope they didn’t damaged the router.
I am also thinking about Tomato. I’ve downloaded the Tomato and ready to install.
I will post to let you know how it worked out. It may be telling if I still have the same problem.
- brdoddsjrDec 24, 2017Apprentice
TimePilot, how is your wifi speeds?
