JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
brdoddsjr
Dec 24, 2017Apprentice
TimePilot, how is your wifi speeds?
Timepilot
Dec 24, 2017Guide
I haven't tested them yet - but no complaints from the family - more concerned about the stability and dropouts/failed connects
- gandmclarkDec 25, 2017Guide
V1.0.9.18.1.2.27
Just purchased this router and updated to the latest firmware. Most of my devices worked without issue but two did have a problem that I eventually solved.
Roku 2 device was getting code 003 ( unable to resolve dns ) problems, apps not working etc.
Motorola G5S Plus Android 7.1 WiFi OK but no outside internet no-connection.
I tried everything until I decided to go to security -> access-control and 'turn on access control' 'Allow all devices to connect' Even though I am not blocking any devices just enabling this got the above devices working. I'm not sure why the default setting of not enabling access control would stop the above two devices working.
- Davide66ITDec 25, 2017Initiate
That was a good suggestion.
I enabled device access control and authorized the devices.
I then again upgraded to 1.0.9.18 and no issue raised all devices work, even the Glaxy A3 that could not navigate internet at the first attempt.
- OuinDec 25, 2017TutorNo more drop issue with version 1.0.9.20 last two days. Max speed on 2.4G 120Mbits/s and on 5G 320Mbits/s.
I will continue to report next days about this beta release.
- alexchoiDec 25, 2017Tutor
gandmclark solution works for me. Turn on access control, and the problem of android devices got no internet fixed. I am running on version 18 now. Thanks.
- brdoddsjrDec 25, 2017Apprentice
Day 2 on the hot fix. Everything stable and speeds are good.
Smart Connect: On
QoS: Off
Guest Network: On
Using Reserved and DHCP on wireless devices.
- mzguyDec 25, 2017ApprenticeWhich version are you on brdoddsjr?
It would be great if Netgear communicated what a given version is expected to fix.- HWAMDec 25, 2017ApprenticeIs it fixed?? Is it really fixed?? Can anyone confirm a beta version is fixing the 2.4GHz problem? It would be a great Christmas present.
