JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Timepilot
Dec 24, 2017Guide
I haven't tested them yet - but no complaints from the family - more concerned about the stability and dropouts/failed connects
gandmclark
Dec 25, 2017Guide
V1.0.9.18.1.2.27
Just purchased this router and updated to the latest firmware. Most of my devices worked without issue but two did have a problem that I eventually solved.
Roku 2 device was getting code 003 ( unable to resolve dns ) problems, apps not working etc.
Motorola G5S Plus Android 7.1 WiFi OK but no outside internet no-connection.
I tried everything until I decided to go to security -> access-control and 'turn on access control' 'Allow all devices to connect' Even though I am not blocking any devices just enabling this got the above devices working. I'm not sure why the default setting of not enabling access control would stop the above two devices working.
