JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
mzguy
Dec 25, 2017Apprentice
Which version are you on brdoddsjr?
It would be great if Netgear communicated what a given version is expected to fix.
brdoddsjr
.20 Hot Fix. The link is above. Page 4 for me.
- mzguyDec 25, 2017ApprenticeThanks. Can anyone else confirm that .20 fixes the issue, or anyone for whom it failed?
- shamarinDec 25, 2017VirtuosoFor me it doesn't fixed my issue with IPTV STB from version 1.0.9.18. For your case just install and try. You can go back to old stable one at any time.
- mzguyDec 25, 2017ApprenticeShamarin,
I know I can install it. I need to know whether it fixes the dropping connection issue for my own reasons. Experimentation is not an option for me right now. That's why I'm asking if someone can volunteer info on that.
What's the IPTV issue? Are all 2.4 GHz connections dropping for you on the .20 firmware, or is that a different issue?
