JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
AtoZ
Dec 25, 2017Apprentice
Installed the .20 firmware hotfix about 5 minutes ago. So far, everything is back up and running. I will give you guys an update when I can. Thanks.
brianhelman
Is the .20 code still beta; I'm not seeing anything that looks like a final release.
