JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Ouin
Dec 26, 2017Tutor
Sorry guys, version 1.0.9.20 is not solving 2.4GHz drop. All my devices connected to 2.4GHz are disconnected and no more ping.
Netgear developer do you expect a solution next day? This situation is not acceptable!
brdoddsjr
Dec 26, 2017Apprentice
Still stable on the .20 Hot Fix. Almost 3 days now. Speeds are good. Android is stable.
- AtoZDec 26, 2017ApprenticeFyi, my router worked for 5 days with .18 before failure. Am hoping .20 works for all of us, but i want to see it run for 2 weeks before i get happy. Im only 12 hours on .20. Good luck.
- Retired_MemberDec 26, 2017I'm jumping consumer ship and buying enterprise/commercial gear with separate APs and Routers. I was initially very pleased with the R7000. It seemed like a stable and cost-effective purchase. However, buying two-high-end-all-in-ones is enough to buy entry level/mid-tier enterprise gear that has better support. Bye NetGear you've lost a customer forever.
