JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Stale
Dec 26, 2017Aspirant
Holy cow, I just ran into this issue HARD on 1.0.9.18, after running on it basically since it came out. I saw that the .20 hotfix was out, and even attempted a factory reset on that version as well. After the factory reset the only thing I configured was the basic Wifi settings, and clients immediately had issues, basically everything else was default.
I also tried downgrading back as far as 1.0.9.6, and the same problems came up at every previous version. It seems like once this bug triggers, it's pretty darn persistant.
So after a lot of random attempts, I re-upgraded to 1.0.9.20 (along with another factory reset). While my problems were primarily related to the 2.4Ghz band, I went ahead and tried something different. I disabled the 5Ghz radio completely, and changed the 2.4Ghz radio to disable the 20/40Mhz coexistance & set the mode to 54Mbps specifically. Sure enough after that the 2.4Ghz band appears to at least allow clients to connect (granted the performance is relatively terrible).
Based on this behavior, I don't think the 1.0.9.20 version is fixing the issue on all devices. I really hope that a complete software fix comes out soon on this, as it stands I'll have to replace the router within a few days (family complaints), and I'm sure not replacing it with another Netgear if these problems still exist.
- StaleDec 26, 2017Aspirant
One thing I'm noticing, is that the 2.4Ghz band has massive latency spikes across the board when it's broken. Reducing the mode down to 54Mbps also reduces the latency spikes, though they are certainly still there (seeing spikes of +100ms or so at 54Mbps, but at 289 or 600Mbps the spikes jump to 1000-2000ms, with lots of packet drops.
Seems like 54Mbps might just be masking the problem, but at least it get's clients somewhat reconnected.
