JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
alange81
Dec 26, 2017Aspirant
I am having the same problems with the 5G network. It keeps kicking everyting off the network and has to be reset. Is there a fix for this yet or is there one on the way?
I am up for suggestions!!!
Diggie3
Dec 26, 2017Luminary
The suggestions seem to be a combination of:
* Turn on QOS, update the QOS database/engine, then turn it back off
* Turn off the guest Network
* Turn on access control and allow all devices
- AaronB483Dec 26, 2017Aspirant
Will I did it. Installed Tomato firmware about three days ago. It was something I wanted to do for awhile, but now feel I was force to.
The setting pages pop up faster.
The login is faster.
I can find the setting I need easier.
But there are so many settings I don’t know what they are or how to use them.
Wifi seems faster – Now getting 9.8Mbs instead of 6.8Mbs
That may be anecdotal. Xfinity may have sped up my connection.
I am still struggling with getting my laser printer to work with the USB connection. Both with linux and Windows 10
I feel satisfied with the changes.
For those that have made the same changes with adding Tomato firmware, please post your experience.
- HWAMDec 26, 2017ApprenticeI did the same after buying a new Linksys WRT1900ACS. I can't afford downtime. I guess I am going to use the R7000 as an extra access point with Advanced Tomato. I don't think I have the energy for testing a Netgear firmware again. I did everything to make it stable again, all without success. Now it's time for Tomato.
- StaleDec 26, 2017Aspirant
Let us know how it goes, and which build you used. I literally was just thinking about this too, as I'm out of ideas with the stock Netgear firmware, and don't really want to buy a new router prior to CES in a few weeks. I'm tempted to tryit tonight too now.
If Tomato works to bridge the gap, all the better!
