JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
jsw5596
Dec 26, 2017Aspirant
Update has caused my internet speed for wired systems to drop to 12mbps, where wireless connectivity is around 90mbps. Before update my wired connections were around 90mbps. When I go back to older firmware my wired speed increases to where it should be.
