JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
pierreca
Dec 27, 2017Aspirant
Yesterday updated firmware to R7000-V1.0.9.18_1.2.27
All my android devices can wifi connect but no internet.
IPads work fine and PC based WIFI connection OK.
downgraded to R7000-V1.0.9.14_1.2.25
Android system ok , and all the rest ok
Today applied hot fix R7000-V1.0.9.20_1.2.28
this fix not working
downgraded to R7000-V1.0.9.14_1.2.25 again
Android system ok , and all the rest ok again
brdoddsjr
Dec 27, 2017Apprentice
On the wireless side: Smart Connect: On, SSID: Enabled, Coexistance: OFF, WPA2-PSK(AES), Channel: Auto, Mode: Up to 600 Mbps, Transmit Power: 100%
QoS: OFF
Nothing on USB
Guest Network: only 2.4 enabled with open security
Access Control: OFF
One the WAN side the only thing is I disable IGMP
MTU: 1500
- brdoddsjrDec 27, 2017Apprentice
One other thing is i bought my R7000 when they first came out, so I've probably had every version of firmware. And I used it as an Arlo base station as well. This router has been upgraded may time.
