JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
brdoddsjr
Dec 28, 2017Apprentice
Speed are good. 50M down and 16M up on a 50M service. (Speettest on native Android)
mzguy
I'm giving .20 another try. Speeds improved. I remembered that after reboot I've always required a sort of ramp-up period over a few minutes, before speeds were good. I have not cancelled my Eero order, given that others haven't had luck with .20. If it's flawless over the course of a week and Netgear chimes in, I'll reconsider. Otherwise, my R7000 will likely be demoted to a switch.
- WrockyDec 28, 2017Guide
Time to move on.
I've tried every available f/w version from every source in the last 2 weeks with this router and the longest it has been up was about 2 days. That was the absolute best and only happened once. Most times it would only last 4 or 5 hours. I can't afford the downtime, the beta testing time and I'm appalled by the complete lack of support from Netgear to acknowledge or repair this issue.
I really hope the issue gets solved so that I can flash it to something stable and sell it. Myself, I've moved on to another vendor's product and have no intentions of purchasing something from or promoting Netgear as a company.
Good Luck all.
- brianhelmanDec 28, 2017Apprentice
I agree. My group of tech friends (probably 8 of us) have all purchased the R7000. I've convinced 5 or 6 other people to purchase it and recommended it to a couple dozen others. I have one friend who just purchased the latest Nighthawk last week. I'm resisting the urge to tell him to return it and go with another manufacturer.
I get that the R7000, especially in my case, is several years old. But Netgear seems to have broken our devices. I cannot be loyal to a company that doesn't appear to be loyal to their customers. I'll be watching for deals on the Asus AC3100/RT-AC88U. If Netgear makes everything right, I'll stay with them. If the a deal for the Asus presents itself first, they'll have gained a customer.
So disappointed in Netgear.
