JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JamesGL
Dec 28, 2017NETGEAR Employee Retired
Hi All,
All issues you have raised are gathered and has been reported. This includes the version 1.0.9.20. I will provide an update with this issue.
JamesGL
Hi antinode,
Thank you for that. I will unpin the said topic. The update I will provide is regarding the issue raised using the latest firmware. The release notes focused on the security issues that has been reported which NETGEAR wanted to address right away.
- Diggie3Dec 28, 2017LuminaryRegarding security, please also alert the developers that:
- There is a topic here claiming the VPN service uses an MD5-based cert. That is, honestly, attrocious if it's true.
- There is still no button in the admin console to generate a new VPN key (replace the old one). This is also super bad.
Please stop ignoring security issues. - AtoZDec 28, 2017ApprenticeWith all due respect, we are way beyond security issues. Netgear broke our routers. How about we seriously address that issue first. I feel like we are just about to get the diversion answer to the last month and a half of useless firmware updates. Now, how about a serious answer....
