JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
JamesGL
Dec 29, 2017NETGEAR Employee Retired
Hi antinode,
Thank you for that. I will unpin the said topic. The update I will provide is regarding the issue raised using the latest firmware. The release notes focused on the security issues that has been reported which NETGEAR wanted to address right away.
Diggie3
Dec 29, 2017Luminary
Regarding security, please also alert the developers that:
- There is a topic here claiming the VPN service uses an MD5-based cert. That is, honestly, attrocious if it's true.
- There is still no button in the admin console to generate a new VPN key (replace the old one). This is also super bad.
Please stop ignoring security issues.
