JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
NukeJr
Dec 28, 2017Guide
Pass thru Bandwidth speeds is limited to 25Mbs. 200+ straight connect. Disable QoS and pass thru nears 200. Reenable = ~25-50Mbs on manual and back to <25Mbs on Dynamic.
Disabling QoS makes gaming latency imposible. "Teleporting" FPS; and "Strict" or "Moderate" NAT at best.
My latency is erratic and rarely below 80ms. This further wrecks havoc on gaming. Some of it is Spectrum sourced (technician to come tomorrow) but numbers are worse through router. Latency numbers were mimicked prior new firmware.
This all started when I upgraded firmware to V1.0.9.18_1.2.27 yesterday. I had no problem with old firmware that was over a year old. I should have noted which release it was so I could revert to it.
NukeJr
Dec 28, 2017Guide
After reading many of the posts in conjunction with my own experience and posts on other sites. I believe I will forego any futher investment in NetGear products. Complaints are numerous and varied and appreciable response has been lukewarm and infrequent. I will be shelving or discarding all my suspect NG equipment. Simply donating them to someone would be giving them a unnecessary frustration.
Thank you NetGear but I think we should see other routers. Good luck but lose my number.
- AtoZDec 29, 2017Apprentice
I received this from Jamesgl last night...
Hi AtoZ, Please provide me the following information. I will endorse you to support team. Name: Phone number: Email Address: Best time to contact: Timezone Regards, JamesGL Community Team
Just a question or two to everyone on this board...has anyone been helped by calling tech support about this issue?! Have they even acknowledged this issue in the last month and a half?! If I am wrong about this, I will get on hold with India or wherever, right now, but I don't think I am. Hey netgear, FIX IT! We didn't cause this, you did!
- shamarinDec 29, 2017Virtuoso
I didn't get it now. But my issue is not releated to Wi-Fi and began only after lealising of version 1.0.9.18. I think we will get it after new year holidays.
