JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
mzguy
Dec 29, 2017Apprentice
brdoddsjr wrote:Folks, my final update. 6 days on the .20 Hot Fix and stable with good speeds. New lease last night and the router resovled correctly. Not errors in the logs.
Good luck all.
My attempt with .20 failed this morning. I've seen one other report of failure that I can recall, and yours is the only success. I would beware if I were you - this firmware / problem must be fragile. If yours doesn't break in the coming days, perhaps some change to your network or device behavior will likely break it in the future. Until Netgear acknowledges the issue, communicates its cause, and points to a fix, no one should assume it's fixed.
brdoddsjr
Believe me, I expected problems. The reason I was chiming in was becasue my experiance was so different. I put my config info out there to help. My router settings are box standard, but my 2.4 wifi devices should be a nightmare. I have printers. laptops, phones, alarm comnponents and tons of different IoT device on the 2.4 radio. I felt like if anyone would have problems with 2.4 wifi stability it would have been my environment. And, I have an early version of the R7000.
