JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
QneelaEbfr
Dec 29, 2017Aspirant
My issue is the same as so many I see on here. A firmware upgrade just prior to 1.0.9.18 crippled my 2.4GHz connections. I moved up to .18 since it seemed to come out so quickly after - with no success. As soon as my Harmony Hub stops responding to voice commands from Alexa I know it is time to reboot the router. With so many people posting about this issue I'm baffled why it hasn't been fixed yet. Additionally, I can see forum posts from 2015 referencing this same issue so it clearly isn't new. Screen shot shows active devices after 2.4GHz craps out.
brianhelman
Dec 29, 2017Apprentice
Do you have a Guest Wireless set up on 2.4GHz? If so, try disabling it. That's not a resolution, but it has made many of our devices usable again.
- brianhelmanDec 29, 2017Apprentice
So, update to my earlier post. Since talking with Netgear Support, my router hung. Not just 2.4GHz .. but 5GHz too. That's the first time that happened.
I've disabled my Guest Wireless 2.4GHz again. If the router hangs again, I'll roll back the other changes Netgear made (see my earlier post).
They did follow up with me after the call (but before the router hung). I don't know how dedicated they are to fixing the problem, but right now it looks like they are putting the resources in to investigating.
- QneelaEbfrDec 29, 2017Aspirant
I will disable guest wireless (argh) and report. Thank you.
- mzguyDec 29, 2017Apprentice
Don't get your hopes up. I ran without guest wireless on .18 firmware for a while, and it didn't help.
- LaudekDec 29, 2017Star
Hi all
Looks like I am out.
Opened the door today to accept a delivery. Discovered it was a new tri band router from a different company. Seems my wife had enough of me spending 30-40 minutes a night for the past month or so trying to stabilize our wifi and ordered it the moment after Christmas online sales began.
So packed up the Netgear running 9.20 and launched the new router. Though all the experimentation on the 2.4 Ghz band and me trying to have our printer work seems to have buggered up the printer. Had to wipe it off the main computer and reinstall it. All is stable for about 5 hours now, including the printer.
Good luck.
