JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
brianhelman
Dec 29, 2017Apprentice
Do you have a Guest Wireless set up on 2.4GHz? If so, try disabling it. That's not a resolution, but it has made many of our devices usable again.
brianhelman
So, update to my earlier post. Since talking with Netgear Support, my router hung. Not just 2.4GHz .. but 5GHz too. That's the first time that happened.
I've disabled my Guest Wireless 2.4GHz again. If the router hangs again, I'll roll back the other changes Netgear made (see my earlier post).
They did follow up with me after the call (but before the router hung). I don't know how dedicated they are to fixing the problem, but right now it looks like they are putting the resources in to investigating.
