JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
NukeJr
Dec 29, 2017Guide
Problem Solved!!!
Bought Linksys WRT 3200 ACM. Pricematched Amazon at Best Buy. Came out $20 more than the R7000 and a million curses less in frustration. I am done with NG. Sorry guys but had to abandon ship. I am going to shoot the R7000 with my new Glock tomorrow.
tulong
Dec 29, 2017Guide
I finally had to flash their router with Tomato open source firmware. So far no drop and the transfer rate on 2.4Ghz has improved greatly. 5Ghz transfer rate is just a little bit better. The range has definitely improve big time. I can go anywhere up stair without getting disconnect as it's used to be. Will see how it goes. At least now the connection is pretty stable. I was thinking the same thing about getting me a Linksys WRT 3200 ACM if it shows sign of problem again.
P/S I have said last time that it's my last post here, but just figure it would helps folks here to get the router working again so here I'm. I'll post my final post here in a week on the result and that will be the last.
