JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
ddurig
Dec 29, 2017Guide
I was able to go about 2.5 days without issues on the hotfix before having to reboot. I have rebooted twice now. Figured I would try enabling QOS to see if that helped. The router ran a speed test which I never saw results for and then rebooted...strangely I can get to the internet now but both the web admin console and netgear genie no longer load. This could be it for me...
