JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
bascaves
Dec 30, 2017Apprentice
try putting your R7k in the microwave at full power. It either will boots your 2.4 Ghz for a moment or at least resolves the frustration forever R.I.P. ;-)
Btw: don't try this at home but in your old shed, in case it gives you a one time fireworks to close off 2017.
I wish you all a great and less frustrating 2018 with a better and healthier router.
