JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Firepsych
Dec 30, 2017Aspirant
1.0.9.18 1.2.27 also giving me problems, not sure if it was dropping connections or the signal was too low to keep all wifi items connected. Dropped back to 1.09.10 for now. Do I need to do the hotfix security upgrade and will this effect my connections? I have wemo, phillips hue, etc and when the router reboots I seem to have to reset all these devices.
