JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
brdoddsjr
Dec 30, 2017Apprentice
Folks, I'm back. I'm the guy running stable on the .20 Hot Fix for a week.
I just lost every 2.4 wifi connection. I happen to be in the router at the time. I watched all (every) of my 2.4 connected devices drop off one by one. Not all at once, but literally one by one. It took over an hour to drop all the 2.4 devices. I have 33 IoT devices on the 2.4 radio. Nothing wired or 5 wifi was effected. No difference between reserved IP and DHCP. I even did a speed test on my 5G connected android phone and got full bandwidth while all this was happening.
Absolutely nothing in the logs. I when into my cable modem and nothing there either. no timeouts, no T4 or T5 errors, so it wasn't WAN side.
I've rebooted only and all is well.
If it fails a second time I'm going to turn on assess control and allow all devices.
Ugh
