JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
vincentw56
Dec 30, 2017Tutor
Continue to lose 2.4. Only a reboot fixes it. 5G works fine. Wish I wouldn't have gotten rid of my Asus router. This one is a POS.
Amlodd
Dec 31, 2017Aspirant
After updating firmware to 1.0.9.18 , all was well for a few days and then Amzon Echo/Dot failed to connect to network and then Nest Thermostat would not retain a connection. This affected both 2.4. & 5Ghz wifi connections.
Resetting these products did nothing at all and the tech support teams at each vendor could not fix the issues - Nest even thought it was probably thier hardware had failed.
In a last attempt to resolve, regressing back to firmware version R7000-V1.0.9.12_1.2.23 immedeatly allowed all the units to reconnect and hopefully will remain stable as they had been for many months.
Hope this helps
