JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Stooby2
Dec 31, 2017Tutor
Just rolled back to 1.0.9.12 1.2.23, which was the version I was on before this debacle started. Everything was stable then, so I'll see what happens now. Enabled 5ghz and my guest channel as before.
Stooby2
Dec 31, 2017Tutor
Stooby2 wrote:Just rolled back to 1.0.9.12 1.2.23, which was the version I was on before this debacle started. Everything was stable then, so I'll see what happens now. Enabled 5ghz and my guest channel as before.
Well that didn't work. I can't be bothered with this anymore, taken the router out and running the Virgin Superhub again for now. I'll look into returning the router as it's less than a year old.
- mzguyDec 31, 2017Apprentice
Please let us know if Netgear compensates you in some way.
- Stooby2Dec 31, 2017Tutor
I think it's going to be a fight as they say they only offer a 90 day warranty. But as they've buggered it up, I feel a small claims court action coming on. Getting hold of their support is dreadful.
- Yann7878Jan 01, 2018Tutor
Moving back to 1.0.7.10_1.2.3 solved completely the issue for me:- no more disconnections on 2.4
- speed on wire moved from 95mbps to 350mbps
I did it 10 days ago and all problems disappeared.
Try and let me know.
- DjzgfxJan 01, 2018GuideNothing but problems on .20. Switched back to tomato and I’ve got no more problems.
- vincentw56Jan 01, 2018Tutor
Trying it now. Hopefully it works better.
- dristieJan 01, 2018Tutor
Wow, I see nothing has changed since my post on Aug 23 when connections started dropping, when I updated to firmware version 1.0.9.6.
We are 5 months further now. Shame on you Netgear!
Still running rock solid on V1.0.7.12_1.2.5 since Augustus..
After subscribing to this topic and reading almost all of these posts, I definitively do not consider trying to upgrade at all.
So Netgear, hopefully you have a change log. Something has been change after V1.0.7.12_1.2.5, because this version is the last stable version!
So fix it!
