JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Netabc123
Dec 31, 2017Guide
For those still struggling with network stability, I got tired of either the 2.4 or 5 ghz network dropping at random so I ended up disabling the 5ghz network like some suggested in the begining of this thread and it's been smooth sailing through the holidays (.18 firmware). Annoying I essentially have to cripple equipment that Netgear broke, but it's better than mucking with this crap every day. I almost forgot I was even having problems.
