JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Bas99
Jan 01, 2018Guide
Bought a new router (tplink) before flashing tomato on the r7000: what a relief. R7000 is functioning as an access point while the c5400 has become the ‘mainrouter’. No slow data throughput anymore, no 2.4 ghz WiFi problems.
Diggie3
Jan 01, 2018Luminary
I too am likely to go back to 1.0.7.x today.
This is a total joke. Not only am I wasting my vacation troubleshooting my network, but also my home automation and security is also unreliable as a result.
It is amazing that NG still has no fix. This is so bad!
- HWAMJan 01, 2018ApprenticeDiggie3 It is useless to go back. I already tried that, no Netgear firmware can fix it. Install Advanced Tomato, it is great and has a lot of features Netgear doesn't have.
- brianhelmanJan 01, 2018Apprentice
Has Advanced Tomato fixed the KRACK vulnerability? I can't find anything verifying a patch.
- HWAMJan 01, 2018Apprenticebrianhelman I don't think so but I really don't care. What do you want? A stable router or resetting the thing every time. How big is the chance you will be hacked? I guess the chance you win the lottery is much bigger, even if you never play.
