JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
HWAM
Jan 01, 2018Apprentice
Fix is buying a new router. Or wait a a couple of months, maybe Netgear will fix the problem........ You need a lot of patience.
SeanPGH
Jan 01, 2018Aspirant
Solved: I have an AC2200 wireless extender. I needed to upgrade the firmware on it. It was causing my wireless router to choke and drop internet. Been 5 days with no drop.
- HWAMJan 01, 2018ApprenticeSeanPGH Ooh yes we all have to update other devices in the network, it is not the fault of any new Netgear R7000 firmware or the R7000 itself. Sorry for my reaction but I hope it is solved for you. My trust is zero. It can be stable for a few days but 2.4GHz will stop after a while, believe me. What a coincidence we all have the same problem at the same time and Netgear is working 24/7 to generate betas. They know they did something wrong.
