JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
dristie
Jan 01, 2018Tutor
Wow, I see nothing has changed since my post on Aug 23 when connections started dropping, when I updated to firmware version 1.0.9.6.
We are 5 months further now. Shame on you Netgear!
Still running rock solid on V1.0.7.12_1.2.5 since Augustus..
After subscribing to this topic and reading almost all of these posts, I definitively do not consider trying to upgrade at all.
So Netgear, hopefully you have a change log. Something has been change after V1.0.7.12_1.2.5, because this version is the last stable version!
So fix it!
