JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
TJsmudger
Jan 01, 2018Aspirant
I too have upgraded my R7000 to the following firmware: V1.0.9.18_1.2.27
My household is experiencing endless and very FRUSTRATING wifi dropouts after this update, where I need to either reboot the router {power off} OR by hitting the [Wireless Setup] page and select the 'Apply' button for existing configurations that are already set.
I have 2.4 & 5Ghz SSID wifi channels Enabled. Each have a different passwords assigned. Smart Connect is Disabled.
I have the Guest wifi networks enabled for each 2.4 & 5Ghz enabled, same password.
I have utilised the above configuration for several years.
It is my current opinion with information known at this stage, the latest firmware update is plagued with a bug that is resulting in the wifi behaving poorly and inconsistently.
Netgear, what level of testing is run before publishing a new firmware release? it appears that I'm not the only person to experience these disappointing outcomes.
Thank you
Tony
- gizholaJan 01, 2018Aspirant
I've disabled my Guest network and it seems to have helped.
- AtoZJan 01, 2018Apprentice
Unfortunately, many of us have been here. It doesn't usually work. When you turn off the guest network it basically resets router as if you rebooted. I hope it works for you.
- Diggie3Jan 01, 2018LuminaryNone of these helped me:
- Updating QOS database
- Making sure QOS was off
- Turning access control on or off
- Turning off guest Network
- Applying 1.0.9.20
