JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
TJsmudger
Jan 01, 2018Aspirant
I too have upgraded my R7000 to the following firmware: V1.0.9.18_1.2.27
My household is experiencing endless and very FRUSTRATING wifi dropouts after this update, where I need to either reboot the router {power off} OR by hitting the [Wireless Setup] page and select the 'Apply' button for existing configurations that are already set.
I have 2.4 & 5Ghz SSID wifi channels Enabled. Each have a different passwords assigned. Smart Connect is Disabled.
I have the Guest wifi networks enabled for each 2.4 & 5Ghz enabled, same password.
I have utilised the above configuration for several years.
It is my current opinion with information known at this stage, the latest firmware update is plagued with a bug that is resulting in the wifi behaving poorly and inconsistently.
Netgear, what level of testing is run before publishing a new firmware release? it appears that I'm not the only person to experience these disappointing outcomes.
Thank you
Tony
gizhola
I've disabled my Guest network and it seems to have helped.
- AtoZJan 01, 2018Apprentice
Unfortunately, many of us have been here. It doesn't usually work. When you turn off the guest network it basically resets router as if you rebooted. I hope it works for you.
- Diggie3Jan 01, 2018LuminaryNone of these helped me:
- Updating QOS database
- Making sure QOS was off
- Turning access control on or off
- Turning off guest Network
- Applying 1.0.9.20- brianhelmanJan 01, 2018Apprentice
So, to state the obvious, there's nothing worse that inconsistent results that cannot be reliably duplicated. In my case, turning off Guest WiFi has somewhat stabilized my WiFi. I'm still experiencing sporadic slowness, but not 100% of the time. I'm on 1.0.9.14.
I'm more inclined to replace the router with another manufacturer than put Advanced Tomato on my 7000. I'm concerned that the hardware has been damaged.
Just to give everyone a bit of an update, Netgear Support did reach out to me. Because of some confusion over which account I used to register my router there was some delay. I have uploaded debug logs to the ticket, but that just happened today. Hopefully they'll see something, but I'd expect another week or two before we see another release of any kind.
I'll be limping through usage until then or until I see the router I am monitoring go on sale. I'd like to stay with Netgear, but this whole ordeal has made me question my loyalty. If they manage to fix this before I see a sale, that would probably get me to stay. There is a group of friends I see daily at work. We all have the R7000. We were closed for the last week, so we haven't discussed this issue for a couple weeks. I'll be curious to see if they are also experiencing the issues.
While all of this has been frustrating, I can't help but see the irony that the very reason I bought and stayed with Netgear -- that they actually issue patches! -- is what has burned me. I don't see me going to many of the consumer manufacturers because of their commoditizing of the product -- ignoring it once the sale has been made.
I'll send updates as I have them. If anyone else has been contacted by Netgear support, I'd be curious where you stand.
