JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
alexchoi
Jan 03, 2018Tutor
I am using the 18 firmware. I don't have the 2.4G drop problem. My problem with android phones not getting internet has been fixed with activiating access control. But now I discover that my wifi speed getting very slow. Today, I run a speed check by connecting the router with my computer through a lan line, I was getting speed around 270Mbps download and upload. I turned on the computer's Wifi (computer is literally just 2 or 3 feet next to the router), 5G getting 30Mbps download, 10Mbps upload, 2.4G geeting 80Mbps upload and download. The speed is really horrible. Netgear should do something about it.
- HWAMJan 04, 2018ApprenticeThanks Dave. Finally communicating to the people. Please tell us more. Keep us informed. Does it has anything to do with the krack fix? Why is reflashing an old version not working for me?
He guys!!!! Did you see it?? Netgear is admitting there are problems and they need our help.
