JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
bolmenroggan
Jan 04, 2018Aspirant
Hi
Where do i find old firmware such as 1.0.7.12? Please help me.....
HWAM
Jan 04, 2018Apprentice
https://www.netgear.com/support/product/r7000.aspx#download
At the bottom, previous versions.
- bolmenrogganJan 04, 2018Aspirant
Is anyone who has tested v1.0.9.20 - HOT FIX?
- HWAMJan 04, 2018Apprenticebolmenroggan Yes, read the posts. It is not solving the problem.
HWAM What the hell are they doing?
