JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Kendigr
Jan 04, 2018Aspirant
The exact same issue continues after latest firmware update. I updated the firmware, did a hard rest and have tried various types of settings like disabling DoS protection. The router randomly drops one or the other band, it will drop 2.4 then i have to go into the router make a setting change and save then it will come back up. Later it will drop the 5ghz and I repeat the procedure (or just un plug and plug back in the router). I am going to give Comcast a call and just rent their new router. This has been going on for months and I run a busines which can't afford this type of down time.
