JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
nightshark
Jan 04, 2018Aspirant
If anyone is interested I loaded this firmware. Apparently the R7000 and Asus RT-AC68U have the same hardware. It was been ported to work with our routers. No issues since loading it. You can use the Asus router app on your phone if you need that. Still a pain but I couldn't wait for a fix from Netgear and wasn't going to sacrifice security.
Diggie3
Jan 04, 2018Luminary
Does anyone on the thread know of a particular action they can perform on a device on their Network that causes the problem to occur extremely rapidly/reliably, other than just waiting?
Being able to reproduce the problem rapidly is probably key to fixing it. If you know how to trigger it quickly and reliably please post what the device is, what you do with it, and any information you have about it's own OS/firmware version.
