JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
1k
Jan 04, 2018Aspirant
Hi,
Just installed V1.0.9.18_1.2.27, and wireless 2,4 and 5 units seems to loose connection with router. Not using SmartConnect or QoS. I need to apply setting every day now and router seems slower than useually to administrate. I tried reset it several times without positive result for longer time.
Are there any progress with this issue ? since it's a bit annoying. Please advise for a solution!?
- BeechyboyJan 04, 2018Tutor
Just switched to Xwrt-Vortex
http://xvtx.ru/xwrt/download.htm
.... and your problems will be over
KRACK fixed
- lsummers72Jan 04, 2018Guide
I upgraded to the new hotfix R7000-V1.0.9.20_1.2.28 and it's still acting up for me. The odd thing is, this whole time I've been able to use RDP from outside the network to connect to a computer that's connected to the router via ethernet and another via wireless, but neither one will connect to the GUI via browser or any other website. Would that make it a DNS issue? It will allow incoming connections, but not outgoing ones and port forwarding still works.
- brianhelmanJan 04, 2018Apprentice
I thought it might be DNS as well, but wired devices work just fine:
2.4GHz Devices: If you're on a service, it continues to work (e.g accessing gmail). If you try to access a new service (e.g www.yahoo.com) it will fail. This feels like a DNS issue*.
5GHz Devices: Generall they would work fine, but lately they had the same issues as 2.4GHz
Both bands: If you detached from wireless, you couldn't re-attach. Devices such as my google homes would go in to re-configure mode (advertising as AP's so you could attach directly to them to configure).
Wired: Worked fine. I could still access the other wired devices on my network, but not my wireless ones. Internet worked fine. I could NOT connect to the GUI on the router (which also prevented me from getting the log/debug information).
*a DNS issue wouldn't prevent wireless devices from re/attaching to wireless. With respect to wired devices, they wouldn't get DHCP addresses from the router. I had to hard-code an IP to my laptop to test (including adding DNS information).
To me, it feels more like a DHCP issue. It looks like the default lease is 65ish hours. My current lease was obtained on 2 January at 22:41 and expires on 5 January at 15:28 . DHCP will generally send a keep-alive at half the lease, to verify you're still there. I'm wondering if something has happened that causes the leases to expire. This still wouldn't prevent wireless devices from re-attaching though. They don't even get to the lease reqest, as far as I can tell.
- FirepsychJan 04, 2018Aspirant
Hmmm, some newbee questions, if I change firmware to Advanced Tomato or the xwrt (that is the R7000 380.69 version) will I see changes (increase/decrease in speed, signal strength, etc). and I assume that I can switch back to netgear firmware if they get these problems sorted out? I downgraded to 1.0.7.10 (most people went to .12 I see) and seems to be stable. I had 1 problem with a wemo switch losing, then getting back a connection (not sure if it was 2.4 or 5).
