JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
LM22
Jan 05, 2018Aspirant
After upgrading, my 5ghz band does not work. My HP printer will no longer connect at all. Has anyone tried the latest hotfix? I'm getting quite frustrated and considering a Linksys.
shoman94
Jan 05, 2018Apprentice
I did a full reset using the button and setup everything from scratch.... No backup/ restore.
