JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Retired_Member
Jan 06, 2018HWAMthat firmware was meant for you, not us :smileywink:
pendawsyou should try for a tftp recovery, if that doesn't work your last option is trying for a serial recovery
Anyho, I've had 0 issues with 1.0.9.18, infact I haven't had any issue the past 4 or 5 releases.
