JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
MannyN
Jan 06, 2018Aspirant
Same instability issues that other users have reported. Wifi connections just drop off for no reason (sometimes as frequently as 10 min after reset) and it is getting to be very annoying. Having to reboot the router everytime this happens. Seems to go offline even when no activity on the router. Have not been able to identify a pattern yet. Have devices connected to both bands, QoS is not enabled.
