JamesGL
Dec 19, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 08, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
Alfik
Jan 06, 2018Aspirant
I've been a happy user of latest Tomato by Shibby for 2 weeks- very responsive and easy to setup- tip for an average user- just do not touch the parametres you do not understand- leave them as default.....
I thought that wifi range was a bit shorter compare to original soft, but played again with 5GHz setup (set region to US and channel above 100) and now everything works great....
For me the best option to survive current Netgear's problems..... The only problem is, that you may not want to come back to original firmware.. :-)
rogier64
Jan 06, 2018Luminary
I agree, once you have a stable alternative firmware running you won't go back. For me it is Asus XWRT-Vortex. Users who use the Genie app on a mobile phone, you can use the Asus Router app with XWRT-Vortex firmware.
