JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
mated
Jan 06, 2018Aspirant
Just throwing this out because my router has mysteriously beome stable (>1 week)
I have had the same problems with 2.4 Ghz and 5 Ghz dropping.off - inluding google Homes (5 Ghz), Logitech Harmony(2.4) , Samsung phones(5 and 2.4), Yealink light bulbs(2.4) and ,,, Many of these devices are with 10 feet of the R7000. I went through the upgrades from .14 to .18 to .20 without any significant differences over the past 2 months. I tried many of the parameter changes (QoS, guest network, disabling 5 Ghz ...) but they didn't seem to help much - still resetting the router (from GUI, power plug, Wifi button) to get devices back online (my wife just turns the R7000 off and back on). Have never lost a wired connection, but an wired android box has been acting strange (not sure if it's related)
One thing that did help a bit was schedulling the WiFi off for 30 minute every night. It just made the problem happen less often though.
Here are my questions: For the past week I have been stable without any further changes. The only change has been the ambient temperature in the room has dropped about 6-8 F due to the cold snap we've been getting in Toronto. Has anyone noticed any corelation to the temperature? Did the firmware upgrade which causes the problem upgrade the firmware of the WiFi chipset (might explain why certain downgrade paths do not fix the problem)? Could the possible WiFi chipset firmware upgrade have pushed up the thermals?
rogier64
Jan 06, 2018Luminary
mated, I'm not sure if the temperature causes unstable wifi. My R7000 was stable until I updated the firmware due to security issues. After the upgrade I never got the router stable, even restoring the firmware to the version that was previously stable did not help. That's why I thought the router had a hardware failure. I was about to buy a new one, but I flashed XWRT-Vortex firmware. This solved all problems for me. In this firmware you can read the chipset temperature (cpu: 138F, both WiFi: 118F)
- JofreJan 07, 2018Aspirant
Yes, I totally agree with you. Flashing the XWRT-Vortex firmware also solves the Openvpn server MD5 issue!
