JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
decalpha
Jan 06, 2018Guide
I made the mistake of updating router to 1.0.9.18 from 1.7.x.
After the update none of the devices could connect to 2.4 GHz. And, one of my mobile devices only supports 2.4 GHz.
As a result, I tried R7000-V1.0.9.20_1.2.28 [BETA], but with same results.
Am currently back on 1.7.x, which is not a ideal situation but have no other choice.
Is there a stable firmware from 1.9.x series ?
What are other alternatives if any?
Diggie3
Jan 06, 2018Luminary
Netgear, why don't you give us a test build without Disney Circle running? It was introduced around the time the firmware started going wonky, it's job is to interfere with traffic, and even when it's turned off it's still running on the box.
It would be interesting to see if a build with no Circle integration works okay.
