JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
bolmenroggan
Jan 08, 2018Aspirant
Hi!
What is best for R7000?
AdvancedTomato or Xwrt-Vortex?
rogier64
Jan 08, 2018Luminary
bolmenroggan wrote:Hi!
AdvancedTomato has an overwhelming amount of settings while XWRT-Vortex is based on Asus firmware with less settings. There are still a lot of extras compaired to NG. You can setup 3 guest networks per band, so up to 6 guest networks. You can run OpenVPN (I use NordVPN) The GUI is perfect and very informative. Fallback to 3G/4G with a USB-dongle and it has true HW acceleration drivers build in. After a lot of unsolved problems with NG firmware I use it for about 8 month now without any issues.
- Diggie3Jan 08, 2018LuminaryIt is interesting some people have success with 1.0.9.6 since Circle was introduced in the next release, 1.0.9.10.
I really would like to see a test FW with Circle completely removed. - bascavesJan 09, 2018Apprentice
Hello,
As I posted earlier I am still on V1.0.9.6_1.2.19. Which for me was the first release after many brought some basic stablity. This without turning on.
1. Guest network
2. QoS
3. DMZ
4. VPN
Hence not a single feature you would expect useful from a modern SOHO router.
Netgear as many other companies are very geared to the US market, forgetting that many other users outside this market don't need features like Disney Circlel That even would break things. Also the NSA steered and sponsored data-collection that Netgear as US company does probably breaks things and isn't really appriciated by the rest of the world.
