JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
potamus29
Jan 08, 2018Guide
After the update started having problems with 2.4Ghz, showing as connected on phones and tablets but unable to access the internet. Then 5Ghz joined in. Ended with no connection other than ethernet to PC.
Rolled back to earlier firmware and it's mostly ok but the PC just dropped the connection. I hope it was just a one off.
So Netgear, what gives?
